growling noise-1991 7.3
New to the forum, just spent a couple hours reading posts.
1991 ATS turbo 7.3 manual shift. Truck is great in 2wd When I lock the hubs (in 2wd) I get a growling noise around 55 mph + If I lock the hubs and put in 4wd, I get another similar but different (louder) growling only in OD at around 65 mph. Above or below 65, no noise. I don't know if both problems are related. I pulled off both hubs and the grease in the bearing looked good. Any ideas? Thanks Howard |
same problem
i have a 96 1 ton 2wd manual tranny get same noise at 50 to 55mph have you figured it out yet
are your tires mached front to rear on the 4x4 if not it the diff tire sizes cause the tcase to spin at differ speed and can burn up a tcase
