Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Drivetrain 911
Old 11-28-2007, 05:23 PM
f250ghost f250ghost is offline
REAREND SABOTAGE
Some jackass decided to loosen all 4 of my Leaf Spring Bolts on the rear axle, driver side. I know it didnt just work itself loose because I recently re-torqued the bolts. At about 60mph, they broke loose and the rear end of my truck was free to move at will. I stopped at the nearest Wal-Mart, and did a walk around where I noticed that the bolts were pretty loose. So loose, that I got six turns with my fingers before they even touched metal. Anyway, long story short, the truck is sitting in the driveway, leaf springs out of alignment, and possibly the axle. And, if you're looking at it at a good angle, it looks like the tire may possibly be bent in towards the truck. Any ideas? I leave for Iraq in less than 6 hours and I need to get it fixed ASAP! HELP!!!
Old 11-28-2007, 05:41 PM
willholl79 willholl79 is offline
use a tape measure and measure front hub to back on both sides, with the front wheels straight. This should tell you if its out of wack. With a floor jack and a pry bar it should be easy enough to straighten out. Thats a quick fix, it should be taken to an alignment shop sooner or later.
Knock em dead in Iraq. THanks for your service!
Old 12-01-2007, 04:30 PM
We took a closer look at the driverside rear leaf springs and found that the alignment bolt that goes through the leaf springs was sheared off when the axle broke loose. I'm in Iraq now, but Aaron (greenf350) is going to repair the leafsprings and pins. Hopefully it won't be too expensive to fix. Thanks for the advice and support willholl!!!
-Ben
Old 12-01-2007, 04:46 PM
NOVAJOE105 NOVAJOE105 is offline
Man that sucks. I can't believe someone would do something like that to ya. Glad you did not have a wreck. Be safe and come home soon.
Old 12-01-2007, 04:55 PM
jostaman jostaman is offline
Smile glad you r okay
Thank you for your service..
Old 12-01-2007, 08:44 PM
TexasR.N. TexasR.N. is offline
Infidel
Sorry to hear about your truck. Stay safe in Iraq and we'll keep you in our prayers.
Craig
Old 12-01-2007, 08:55 PM
owtcast owtcast is offline
You might want to tell him to inspect the lift blocks REALLY CAREFUL to make sure they haven't cracked or crushed any at all. I've seen some of them crush and do the same thing your's did. Be safe in Iraq and thanks for your service.
