Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Drivetrain 911
Old 11-26-2007, 07:53 PM
z-man z-man is offline
Help! Can't remove front hub lock
Hey guys, have any ideas for this one?
I'm trying to replace the ball joints on my 99 4x4 dually.
Just getting started, took out the snap ring on the passenger side hub lock and tried everything I could think of to remove it before resorting to violence.
Most of it is now in pieces, but the main body of it is still stuck in the hub. I have never had one of these stuck like this. They usually fall out, or just need a tap...
Thanks in advance
Mark
Old 11-27-2007, 06:54 AM
USAFdieselman USAFdieselman is offline
I had to put a piston ring compressor around mine and use the extra leverage to get mine out. It was a PITA!
Old 11-27-2007, 10:46 PM
lilredpowerstroke lilredpowerstroke is offline
Keep beating on it. They probably been in there since new.
Old 11-28-2007, 06:39 PM
Finally got it out last night. Had to use the air hammer & chisel bit to get it out. Didn't mess up the hub too much, but I think the corrosion got to it before I did. Unfortunately, this is a pre-3/99 truck so I get to shell out $600 for a new hub.
