mad vibrations - Ford Powerstroke Diesel Forum
Old 10-03-2012, 07:36 PM
mad vibrations
Hey guys I need help going in the right direction, any help would be appreciated. I have a 2004 Crew cab f350 SRW 6.0L powertroke with pro comp 6" lift. The truck was great until the other day when I reversed over a curb I noticed a vibration coming from under my arse while driving down the road only at 40 mph+. I had to give it alot of gas to climb the curb as I was against it. Now I have the vibration which seems to be getting worse and a clunk when i left of the gas and another when im back into the pedal. (only while going faster than 10 mph) I dont get the usual slam from a dead stop like a u joint.
Also I rode in the passenger seat today and could barely feel the vibration compared to the drivers side. I went underneath the truck and the front drive shaft spins freely in 2wd. Im so lost I cant stand it any longer and this is my daily driver. Oh and when I turn 4x4 high on while driving when its vibrating it gets a hair worse but mostly the same. Thanks guys
Old 10-04-2012, 11:29 AM
what a ****in joke this site is...two posts over a couple days old and not even a response GET BENT powerstroke.org peice of **** im off to deiselstop suck on my balls waste of time
Old 10-04-2012, 11:51 AM
Wow what a dbag you are! You come one here and after 2 days you say that? Bumb to the top may have gotten a response to help your situation, i have a response that would probably fix your situation but since im a member of such a terrible sight ill be a piece of **** as and keep my mouth shut. Good luck at the diesel stop. Pull that **** over there and see who wants to help. Better yet take that to outlaw. They will definitely help you hahahahahahaha
What would I be doing right now if I didn't have an iPhone?
Old 10-04-2012, 12:57 PM
i would hope you keep your mouth shut I dont want to listen to a fool.
Stay on your sight lmfao classic example of the level of education on this SITE. piss off.
Old 10-04-2012, 01:31 PM
Im a senior diesel master tech for ford dip****! Im a classic example of who you want to listen to on this site. Good luck with your truck troll! You got some balls coming on here and asking for advice with 2 posts to your name and getting mad that nobody dropped everything to fix your problem. Take your truck to ford and have pay someone to fix it. Your **** attitude on the forum will get you knowhere.
Tags
shaft, vibrating, vibration
