axle off center after leaf spring install? - Ford Powerstroke Diesel Forum
Old 07-18-2012, 08:01 PM
Hasn't moved in 2 years...
I just installed new rear (junkyard) leaf springs, and brand new hangers on a tight budget, rebuilding my stroker to new. The new height is amazing! I love it. However, I swear that that something doesn't look right, but I'm a beginner and this is my first time. Need some thoughts.
After everything installed and truck lowered to ground (just like the chilton manual says) and then all the bolts on the springs and U-bolts were tightened, if i stand on the side of the truck on the passenger side I feel like my rear tire is 2-3 inches forward or "off center," towards the front on the truck. The opposite side got new springs and hangers too and looks completely centered. Tire isn't sticking out noticeably or AT ALL when standing looking front to back.
Don't want to put it on the road till i figure out if this is possible or is it just late and I was working in the dark. Extremely tired so not sure if my eyes are deceiving me....
Could I have bent my Dana 60 axle by accident while putting on the new springs? Jacked up frame, then lowered axle, was very careful because I'm afraid to hurt her. I find it hard to believe cause this truck is tough as **** and I can't picture just if I improperly jacked it or let axle hang lower while putting it on that this happened. Am I crazy or is it just my eyes going bad? Please gimmie some thoughts. frame bent?? i don't think so. Geeze I'm cracking my second beer now, going insane. Please tell me Everything is fine. Should I let the tires roll a few feet and see what happens? Now I really feel like this isn'french to me..t possible if the other side is center. completely
Old 07-18-2012, 09:00 PM
The rear is a Sterling 10.25, 10.5 or Dana 80 if DRW depending on year and unless you got in a accident, you didn't bend it. Start by setting the front wheels straight ahead and measure both sides from the center of the hub. If there is a significant difference, loosen your ubolts and check that the center pin is in the right place.
