Same old ABS, O/D flashing, speedo droped off - Ford Powerstroke Diesel Forum
Old 03-14-2012, 08:35 PM
Not new to the forum (use it all the time for information), just new to posting.
The Vehicle is a 2001 F250, 7.3L 4X4 142,xxx miles. Exhibiting the standard Rear VSS problem. First visual inspection of the plug, wires, sensor all looked ok but I replaced the sensor anyway and none of the problems went away. Next, visually inspection of the tone ring through sensor hole by jacking up the rear diff and rotating the tires, it looks ok. Also, checked the ground by the drivers headlamp mentioned in a thread on here.
Let me back up, first the ABS light was just fading in and out randomly for almost a month and never left any codes behind, no other problems. Then the ABS light would stay on longer, and the speedo started bouncing. This lasted about a week. And this past weekend it gave all symptoms and has not gone away. During all of this I don’t know if the service engine light came on at all, as it has been on for a glowplug problem that I have not had time to fix yet for the duration of this failure.
I could not get any codes from the ABS System because my scanner could not communicate with it. But there were no additional powertrain codes.
I am at a loss as to where to look now, any help would be greatly appreciated.
Thanks in andvance for anything.
Old 03-15-2012, 05:20 AM
Get on a better scanner, one that can communicate with the ABS (what are you using to scan with now?) and see what you get!
Best way to point you to what's wrong....
Old 03-15-2012, 05:51 AM
Let me rephrase that. My snap-on mt2500 is able to scan abs but I get an error when I try on my truck. It scans my wife's truck no problem.
Could this be caused by a faulty abs module?
Old 03-16-2012, 06:16 PM
No help anywhere? I really want to get this resolved this weekend and really don't want to go to a shop or dealer. Please give me some ideas.
Thanks
Sent from my C771 using AutoGuide.com App
Old 03-17-2012, 06:43 AM
Not sure what the communications problem with the module could be, you say "fading in & out" - is that right? Like the light actually "fades" in brightness? (never saw that) OR it's intermittently On & Off?
If it's a fade then maybe it's a power issue?
There is another sensor at the top of the trans that might be involved maybe. I donno, you should certainly still be able to communicate though... You've had a good look at the electrical plugs going to the ABS Module?
Does your truck have a Trans Temp Gauge in the cluster? (major revision to the electrical system in '01 and you're "revised" if you do)
Old 03-19-2012, 04:16 PM
Fixed- ish. I pulled my diff cover today to get a better look at the tone ring. It looked good, there was a little metal shavings in the oil but nothing bad. Cleaned everything up and put the cover back on. Put 3.5 qts of 75w140 in and and took it for a test drive. All symptoms are gone. About 20 min in the drive the abs light started flashing on again, but everything else works perfect.
So now I've got to get the scanner from my cousin and test the abs again.
Until then I'll entertain any other ideas as to what my cause this light to come on with nothing else.
Thanks
Old 03-21-2012, 04:37 PM
The dang symptoms are back. On my way back to work afternoon after launch the stupid Speedo dropped off, and o/d light started flashing again. This time though the speedo didn't even do the bounce or anything. This is really staring to frustrate me and I can't even figure out what's going on.
Please help, I'm out of ideas.
Old 03-26-2012, 03:58 PM
To the top. Hopefully someone has advice on this.
Sent from my C771 using AutoGuide.Com Free App
Old 06-18-2012, 01:04 PM
Is there a resolution for this issue ? I'm having the same symptoms. All but the ABS.
