I was clearing a wooded lot in front of my house and found a soft spot . I put it in 4 Wheel High ( switch on dashboard) then i felt the truck jump into LOW instead ( 4x4 light and LOW Range light came on also).. I cant seem to get it to come out tried it in all of the gears ,truck running , truck not running , the light on the cluster is out saying it is in 2Wheel but the front end is pulling any ideas .. Truck has new hubs on front both sides ..... Also the Trans was replace back in may and put about 30K miles since then haven't had to use 4Wheel but i know for a fact it work before hand is the any way i can manually put this thing back into 2Wheel
my email is USRRECOVERY@GMAIL.COM
Should disengage in neutral with foot on the brake.
Maybe check your shift relay. If one side went bad it wont be able to reverse polarity to the shift motor. |
Try putting the truck in 2wd, then disconnect the batteries and let it sit for about 5 minutes then reconnect the battery and see if it clears the computer and resets.
