04 ford 6.0 crank but no start, no pcm comunication, no buzz koeo - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-17-2011, 06:32 PM Thread Starter
Question 04 ford 6.0 crank but no start, no pcm comunication, no buzz koeo
Hi guys Im new here. Hopefully im writing in right forum. I have e-350 with 6.0 powerstroke. with quigkey 4x4 conversion, no egr. We converted it to manual transmission 6speed from 03 f250 sd . I used complete drivetrain from pick up and used my harness . Only diffrence is on pcm in two signal location. To my issue. I drove truck after conversion for almost 1.5 year without issues. One day parked and two days later no start. When turn the key on no injector buzz test and no pcm communication. Check everithing fuses relayes and then it started and worked. On the way to shop hit a pot hole in higher speed and the truck died. moved plug on pcm and started again. Replaced pcm connector lock and it seemed ok. later that day it died in the midle of parking lot and since then its dead. Put new pcm with they paired with my ficm but still same problem.
no buzzer when turn the key on.
do have grounds on all required pins
have power on all required pins
no referance voltage on pin 44 on pcm lug
Now the nice thing.Friend gave my 06 pcm from 6 speed manual. plug it in and the truck started but gas pedal wouldnt work and bunch of dtc.
Checked wire by wire, data links i dont know what to do more.
Please if someone has any ideas please help me im in the end
matus008 is offline
post #2 of 3 Old 09-27-2011, 07:38 PM
There has to be an open somewhere in the harness start checking for resistance in wires if there is a bad one or more it will show to much resistance in the harness.
seabees is offline
post #3 of 3 Old 09-27-2011, 07:40 PM
You can have all the power in the world going to the right components but to much resistance and components wont work properly
seabees is offline
