Front Axle- Ball joints - Ford Powerstroke Diesel Forum
Old 03-26-2011, 05:42 PM
Help! I just spent 8 hours doing my left hand upper and lowers on my '06 F350.. I got new hub lock, wheel bearing, and knuckle seals, installing them with the proper tools. and I even regreased the hub bearings and splines on the axle shaft. On my test drive, I heard a tick, tick, tick and it started around 15mph and got louder as i got faster, when decelerating it would also be audible until i came to a complete stop and became audible again once i got to 15mph again..someone please tell me I did not mess up installing the axle shaft. The knuckle seal is fully seated in the knuckle like it should. help anyone?
Old 03-26-2011, 05:47 PM
Illiana Chapter Director
Manually lock the front hubs in and drive in a straight line until you get to 15+ mph and see if the noise is there. Did you use the special tool to drive the seal on the axle and into the knuckle?
Old 03-26-2011, 06:01 PM
yes i did, I went to the dealership and the service tech was kind enough to let me borrow it until monday as long as i put a $350 deposit on it. The same one in my shop manuals. I also did notice when I switched into 4X4 one time with the ESOF, it went away for awhile after switching back in 2WD, and ever so slightly started back up again
Old 03-26-2011, 06:09 PM
It sounds like something isn't seated properly but not sure. I just did all the ball joints on an 06 and didn't have an issue. Make sure the hubs are turned all the way to the auto setting.
Old 03-26-2011, 07:48 PM
Powerstroke Techie
Feedback Score: 3 reviews
sure its not just the backing plate hitting some rust on the inside of the rotor hub? this is very common after having the rotor off
