4x4 issue - Ford Powerstroke Diesel Forum
post #1 of 2 Old 01-21-2011, 03:18 PM Thread Starter
4x4 issue
Hey folks, I have a 4x4 issue here. I have a 96 F350 7.3 4x4 manual trans with warn manual locking hubs. I just replaced all ball joints and decided while i was doing that I would drain and replace gear oil up front. So i did as well as putting a tube of friction modifier in as well. Now when i lock the hubs and pull the stick into 4x4 nothing happens in high range or low lock. wondering if this may be related? also a little more background is when 4x4 is engaged and truck moving the front driveshaft does turn as it should. the snow is coming so I would like to figure this thing out soon. thanks in advance.
bar and shield 350 is offline
post #2 of 2 Old 02-20-2011, 11:55 AM
strokin95style's Avatar
Probably a bad lockout. I had to switch one out on my truck, (factory manual lockout)
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
