Axle Play in front Differential - Ford Powerstroke Diesel Forum
Old 01-15-2011, 11:31 PM
Had a problem with my four wheel drive not working on my 99 F250 S.D P,S,D.
Took it to the Ford Dealer and they replaced the pass. side hub and bearing .
Went to use the four wheel drive and still not working so I took the hub off(warn)and found the clip came off? I checked the axle and it seems to still have a lot of play in it is this normal? The other side has no play in it.
Thanks
Old 01-15-2011, 11:58 PM
Ther is some when hub is off, do you have the hub off bolth sides?
Old 01-16-2011, 03:46 AM
No, that is with the hub together. I check my friends 02 S.D and it has some
play but not as much as mine and the fact my was just repaired I am wondering if that caused the hub to come apart.
