hubs hubs hubs - Ford Powerstroke Diesel Forum
Old 07-14-2010, 06:24 PM
Exclamation hubs hubs hubs
the stupid vacuum hubs r still on im getting HORRIBLE MPG there locked in all the time from my problem with the t-case issue. if i clip that stupid vacuum line will the unlock n go free?
Old 07-15-2010, 02:06 AM
If you pull the vacuum line off the hubs, it should unlock unless there is internal damage to the hubs. Also check that the bub is turned to the auto setting and not locked. If you do unplug the vacuum line, you may want to cap the line and the connector on the hub to keep trash out of them.
Old 07-15-2010, 04:52 AM
thanka man think u could help me with this problem?
transfer case not working..
Old 07-15-2010, 05:58 AM
Sounds like something in the wiring may be wrong. I'll have to do some research on the wiring. If it is a wiring problem, that would also keep the front hubs locked.
Old 07-15-2010, 07:10 AM
hey ya please do i need to figure this out ha thanks.
Old 07-17-2010, 05:01 PM
any mopre i des?
