95 F-350 brake sticking problem????? - Ford Powerstroke Diesel Forum
Old 05-06-2010, 01:01 PM
Unhappy 95 F-350 brake sticking problem?????
ok i have put on a new master cylender new rubber lines new callipers new brakes new calleper brackets and the front passenger brake still sticks causing it to over heat running 470 deg. in 5 miles as where the driver side is only 345 deg any help please oh i should also say this is a two wheel drive
Old 05-11-2010, 01:05 PM
fixed?????
ok well i did the one thing i was told never to do and well it worked i took off the master and adjusted the stem from the booster by giving it a couple of turns well i lost all breaking so i readjusted it back just a little and well it works now so there it is another problem solved if any body does this remember first your not supposed to adjust this item but if you do it takes very little adjustment to loose your brakes so be carefull
