Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Drivetrain 911
Old 02-26-2007, 01:56 PM
GreenF350 GreenF350 is offline
Angry Ball joint removal?
I am in the middle of trying to replace my ball joints on a 2000 F350 SRW 4X4. I have changed probably 20+ ball joints on the old style axles (serviceable wheel bearings) but I am having trouble with these.....How in the *bleep* do you get the axles shafts out? Is there something I am missing? What about the seal that is just outboard of the axle shaft, inboard of the bearing unit? Everthing is apart, I just need to get the knuckle off so I can get the press in there. THanks for the help, I am searching as we speak, but I gotta get it done so I can drive it to work in the morning.
-Aaron
Old 02-26-2007, 01:59 PM
SCUFFY828 SCUFFY828 is offline
FORD TECH AND ADMIN ....
once the hub is out there is a snap ring inside , then the hub bolts on te back the hub is tight but should slide off axle will actualy come with the hub assembly , get in behind it and pry some of them are very tight due to rust
Old 02-26-2007, 02:01 PM
I will give it a shot. Only thing is my bearing unit (hub) came right off and left the axle shaft. Only thing left in there is a seal(?) and the axle shaft. Bearing unit, locking hub, and brakes already removed. Thanks.
-Aaron
Old 02-26-2007, 02:06 PM
that seal in beng the hub can also be pretty tight , i usually get in behing u-joint and pry a little it should push on out
Old 02-26-2007, 04:09 PM
Marty Marty is offline
International Threat
The axle just pulls out, usually a pry bar does the truck. Gimme a call 443 553 9234 if you need some help.
Old 02-27-2007, 03:26 AM
Got it taken care of...Thanks guys. I definitly don't like the "new" bearing setups. Way more of a pain. Oh well. Thanks again!
-Aaron
