Front Spring Replacement
Only my second post, but I have a problem this weekend. I decided to replace my front springs on my '03 F250. They were originally only 4800# springs, which doesn't seem high enough for the 6.0L. I purchased 5200# instead.
So, I replaced the drivers side first (it was sagged the most) and then I went to replace the passenger side. I cannot get the axle to line up with the spring in order to get the locating pin from the spring into the hole on the axle. I have been trying all kinds of things with the jacks and jackstands I have for hours.......... but no-go. ![]() Do I need to disconnect the track bar, and if so will I be able to re-connect it? Any help you guys can offer would be great. Thanks Roy |
Have you tried ratchet straps?
I've got one on there right now as tight as it will go, but it still is not enough. I could mess around with different placement perhaps.
Sounds like you will have to unhook the track bar then. It can be a pian to reatatch!
Oh my bad,
Welcome to the ORG dude! |
Thanks for the advice, I'll give that a try and let you know how it comes out.
Thanks for the support, I finally got it with the help of a come-a-long. It was a pain in my back, but it is done. Going for a test drive now.
