Speedometer issue!!!!!!!!!! - Ford Powerstroke Diesel Forum
Old 08-14-2009, 12:51 PM
Send a message via AIM to tsteel
Ok story is 97 F250 stroke with 5 speed. ABS light is on, Odometer is not working or even showing, Speedometer is not working, and of course cruise is not working, and not sure if this has to do with it or not but NO HORN! I have changed the ABS/Speed sensor in the rear dif twice with no change. So what should I check? mini fuses are ALL GOOD! Fuses under hood and relays unknown? I dont know what goes to what in the box under the hood so thats one reason its unknown! Someone help me as I have been trying to figure it out for 3 weeks!
Old 08-14-2009, 12:59 PM
Tennessee Powerstrokes
SixStringMaddness just went through the ABS problem. He had to replace some brake lines, as for the other things I am not sure at all. Hit up Scruffy828 or another of the Ford Techs will be by soon so here is a free bump.
Old 08-14-2009, 01:06 PM
GoFast thanks for the bump! Im not sure its a actual brake issue. I think its more of a electrical issue somewhere. I have a buddy that is a Ford tech but I hate going to him cause its 150 miles one way and then it will only take us like 10 mins to find it and fix it im sure (well thats what usually happens). Anyway I hope someone can help soon cause its buggin the piss out of me!
Old 08-14-2009, 09:51 PM
Anyone????????????????????
Old 08-16-2009, 11:16 AM
Nobody can help?
Old 08-17-2009, 09:40 PM
Still need help!
Old 08-17-2009, 09:49 PM
Just have to wait for some one that has "been there done that" I guess. Hope it goes well for you.
Old 08-17-2009, 10:18 PM
Im not sure anyone has been here!
Old 08-18-2009, 08:25 PM
Finally figured out the problem! A wire was loose and the FUSE in the box under the hood blew due to this. Anyway the dash is still apart so Im going to clean everything tomorrow before putting it all back together!
