- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Front end squeal(ish) noise
I started getting this intermittent noise yesterday. It appears to be coming from the left front. Wheel bearing is only about 6000 miles old. If any of you remember the commercial about some sort of lube that was better than everything else where they put lubes on a bearing like thing and tried to stop it with another piece of metal. The sound is almost like that. Swapped my Warn lock-out for the factory one to test it, no difference. Tried it in 4 hi, hubs un-locked and no noise. Any ideas, the least expensive the better, as I just put $260 worth of front brakes on today, the noise was there before hand.
| Sponsored Links |
thats a tough one, who did your brakes? you can use a floor jack and take off your tire and turn your hub by hand and see where its coming from, also you can check if your bearing is bad by jacking it up and try moving your tire vertically back and forth if youve got alot of movement its bad. a VERY small amount of movement is normal. or your seal on your drive shaft could be bad and something somehow got in there.... guess it depends on what you use it for.... hope you find it
Ok, update. Called a local 4wd drive place along with Marc to get idears of what it could be. The 4wd shop said to pull out the lockouts completely and drive it and see what happens. No difference. Called Marc, he said to try and lock the lock-outs and keep the T-case in 2wd. I did that and NO NOISE at all. So NOISE HUBS T-Case Free 2wd Removed 2wd NO NOISE HUBS T-case Locked 2wd Free 4wd Removed 4wd In summary. it the front end is free spinning, I get the noise. If it is spinning, either hubs locked OR T-Case in 4wd I get no noise. I am at a loss for the noise. I haven't check the springs yet like Marc Suggested. We'll see what happens next. |
Well, I ended up putting the original lock-outs back in and haven't had any noise.
| Sponsored Links |
