universal joints
i am posting this for my dad he cant get the universals out of his 97 wrangler rear drive shaft we have tried a hammer and a vice thus far and blew the vice up so he went and bought a new one and bent the handle with a cheater
anyone have any tips to get them out?? oh btw i belive that they are the oem ones
Put them on the vice , spray w pb blaster let soak for 3 beers, tap the outer ring with a ball peen while applying vice pressure. keep drinking till they come out.
tried something similar to this and they are still soaking but we cant get em out we tried heat and vice and hammer to
maybe if it was a |
You need to use a C-frame press... Harbor freight has them for about 40 bucks.. works like a charm... use that with a half inch drive ratchet or pneumatic impact and they will come right out.
Got the right size socket gotta go big?
I just did my 73 Charger & had them out in 2 beers. Well it's a Heep so they are prolly peened over & wont fit. Try to grind them on the sides to make sure they will fit thru. |
They wouldnt be the old type u-joints that have that glue in them....you have to heat them up very hot and they pop, letting all the glue out a little hole....i had a set i couldnt figure out and they were glued like that.
