Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition > Drag Talk/Racing
Drag Talk/Racing Lets see them slips, How To's, FAQs
  #31 (permalink)
Old 08-27-2009, 12:29 PM
06pwrstrokerbullitt 06pwrstrokerbullitt is offline
Yea if you put it back in 2wd going down the track or wait until your letting off at the end of the 1/4 its going to stay locked in 4wd until the pressure is off the drivetrain. I don't think there is really a mph limit on 4wd just use common sense and be safe about it.
  #32 (permalink)
Old 08-27-2009, 12:30 PM
05_PSD_Erik 05_PSD_Erik is online now
<---- That's My Kid!!!
2006, you should be fine, in the August 2009 Diesel Power, there is an article on Chaz Lightner's 99 SD CC drag truck with a Cummins in it.
"Thw unfortunate drivetrain that is forced to live behind the high-horse Cummins is largely stock, which is a testament to Ford's strength and durability. Special 4r100 TRANNS INTO A stock NP273 chain-driven t-case, which is used to transfer power to all four wheels."
Earlier in the same issue is a dyno day report where that truck laid down "over 600 hp, and that was with 40 pounds less boost thn he normally runs at the dragstrip"
You should be fine!
  #33 (permalink)
Old 10-20-2009, 06:17 PM
Iceman_19 Iceman_19 is offline
Send a message via MSN to Iceman_19
I have a question about this, I am picking up an 02 7.3 with a 6 spd and a manual transfer case. It has a 4" straight pipe, intake, and 100hp superchip tuner. I guess launching it in 2wd would be pointless? How fast and hard can you shift these trans? Im used to banging gears in a T-5.
  #34 (permalink)
Old 10-21-2009, 05:05 AM
2006PSDSD 2006PSDSD is offline
ΜΟΛΩΝ ΛΑΒΕ
As fast as you want, but the shift pattern is pretty large . The few trucks in this years Diesel Power Challenge that were using handshakers were doing 15 second 1/4 times, but they were probably souped up I think
  #35 (permalink)
Old 10-21-2009, 03:16 PM
How do the ZF6s like to be powershifted? Muahaha.
