Tires? - Ford Powerstroke Diesel Forum
Drag Talk/Racing Lets see them slips, How To's, FAQs
Old 05-29-2007, 11:36 AM
Tires?
What tires are you guys running at the track for the best 60' times? My mud tires are just not cutting it - best 60' 1.89 and thats only at around 12psi boost. I love my tires but I may need to move on to something else. A lot of the faster Dodges up here are running Toyo Open Country A/Ts and the Proxes S/Ts. Thoughts?
Old 05-29-2007, 07:22 PM
lukecline
Guest
Posts: n/a
Ive got to do something too, my best 60' is 1.85, but almost always run 1.95-2.00. The only bad thing ive heard about the toyos is tread life sucks. Ive heard good things about the khumos.
Old 05-29-2007, 07:48 PM
Is it the Proxes that wears fast? Their AT should have semi decent life. Which Khumo tire have you heard good things about?
Old 05-29-2007, 09:00 PM
Why don't yall get some street slicks and change them at the track. Even if only on the back, it'd probably help. And they may last a little longer than regular slicks.
Old 05-30-2007, 04:40 AM
well the reson the toyo proxes wear out fast is due to the soft rubber but then again they hook better,but the toyoy A/T's wear real good for being a A/T tire..i would go with a good A/T tire and be done with it like the Bridgestone Dueller A/T Revo and a 1/2 hour before the event add some bleach to the drive tires and that will help soften the tires a little more..
Old 05-30-2007, 06:02 AM
Thanks for the responses. What about the Nitto Terra Grapplers? Looks like almost identical tread pattern to the Open Country AT but a good chunk of change cheaper.
Old 05-30-2007, 07:03 AM
I have had both on currenty just put new Toyos on my 2000 for the second time. I got 35K out of my Nittos and a little over 50 out of the toyos. I also found the nitos wonder on the road much more than the toyo's. Must be the compound. Toyo's cost me 330.00 for 325/60/20's
Old 05-30-2007, 08:22 AM
Do you think that I would be better sticking with the narrower 285/75R16 or move up to the 305/70R16? The truck is currently running 14.0s but has the trap speed for 13.7s if I can get it off the line better. I'm thinking that the 305s might slow me down a bit but will help with the 60'.
Old 05-30-2007, 09:37 AM
you will gain a little in the traction department with the 305's but they will slow you down at the end of the 1/4 so i would go with the 285's and work on the traction verses the wider tires...toyo builds the nitto tires..
extremexj
due you do 4X4 launches or in 2WD?
lukecline
Guest
Posts: n/a
Yes the Proxes S/T's ive heard wear fast. Khumo has an equivalent tire to the S/T which supposedly hooks just as good, but has better tread life.
