Need advice - Ford Powerstroke Diesel Forum
Discount Tire
post #1 of 2 Old 06-30-2013, 03:04 PM Thread Starter
sprksonu's Avatar
Need advice
I am trying to mount my 325/70/17 toyo open country at tires on my 17x12 weld racing Dakar wheels that I purchased from you guys years back, the problem I am having is that there is really not a drop center in the wheels like any other wheels?? Any stores in north phoenix that would be able to tackle this for me without costing a arm and a leg? ThxNeed advice-imageuploadedbyag-free1372629828.389078.jpg
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #2 of 2 Old 07-01-2013, 09:52 AM
Discount Tire's Avatar
Quoted: 9 Post(s)
Thank you for the post, sprksonu. We hope you had an excellent weekend.
I believe the 17x12 Dakar wheel is reverse mount so when mounting tires the face of the wheel needs to be facing down on the machine. Mounting tires on reverse mount wheels can be difficult so a lot of tire lube is needed.
The approved rim width range for tire size 325/70-17 however is 8.5" to 11" so we are unable to mount this combination for you. Wider tires are recommended for this application.
Low Prices! More Choices! FREE Shipping!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
Discount Tire is offline
