What tire size to order from you???? - Ford Powerstroke Diesel Forum
Discount Tire Discount Tire
Old 02-02-2012, 05:07 PM
Got a 2006 F250 Super Duty 4x4 all stock frame. Going to purchase (from you) the Vision 375 Warrior wheels. I think they are the 17x8.5 8-170 18GBF. Correct me if I'm wrong on that. My stock tires are LT265/70/17. I'm also going to order the Nitto Terra 245 Grappler AT. What is the biggest size I can go without a lift and rub issues? Just wanting to fill out the fender wells a bit. Just got a Goodyear Integrity tire from you. Got it in 3 days. Fantastic job. Thanks.
Old 02-03-2012, 06:48 AM
Thank you for the post. We would be happy to help.
The 17" Warrior is 8.5" wide with a +18mm offset in the 8-170 bolt pattern which is perfect for stock suspension.
Details: Vision 375 Warrior custom rims
The largest tire size we recommend the Terra Grappler in for your application is 285/70-17.
Details: Tire Details - Discount Tire Direct
AS you may know, we mount and balance all wheel and tire combinations for FREE and shipping is also included for FREE.
Give us a call at 1.888.459.4080 and anyone of our sales agents would be happy to assist you with this purchase. Just make sure the agent you speak with knows you are a member here so the site receives credit.
Old 02-03-2012, 01:15 PM
Wow...I would have thought at least a 295 or 305 would fit. Lot's of room in there it looks to me like.
Old 02-03-2012, 01:28 PM
Once you start turning the wheel is when you run into rubbing.
With stock suspension I recommend the 285/70-17 size. If you want to push the fitment and don't mind making some modifications, tire sizes 295/70-17 and 305/70-17 are options to consider.
Old 02-03-2012, 01:41 PM
How much wider is the 295 compared to my stock 265?
Old 02-03-2012, 01:48 PM
The 295 width is about 1.25" wider when compared to your factory size.
You can use the tire size calculator linked below to compare different sizes.
http://www.discounttiredirect.com/di...foTireMath.jsp
