8x165 same as 8x6.5 - Ford Powerstroke Diesel Forum
Discount Tire Discount Tire
Old 02-07-2010, 06:11 PM
8x165 same as 8x6.5
says it is on convesion for inches to metric
Old 02-07-2010, 06:13 PM
They are not the same. You cant cross them from an OBS to a NBS and vice versa. It sucks.
Old 02-07-2010, 06:27 PM
you sure?????????
Old 02-08-2010, 04:41 AM
Ya, I have tried back before I knew they were different and spent hours trying to get my OBS wheels to go on my Superduty untill my Dad told why they wouldent fit.
Old 02-08-2010, 07:59 AM
Actually, 8x6.5 is = 8-165.1 One is stated in " (8x6.5) and the other is stated in mm (8x165.1) They are the same bolt pattern.
If you are trying to run wheels from one vehicle on another bolt pattern is not the only thing that determines if they will fit or not. Hub size, width and offset need to be correct as well.
Old 02-08-2010, 08:12 AM
yeah the last guys right. 8x6.5 is equivalent to 8x165mm. the superduty rims are the 8x170mm. So if its 8x6.5 or 8x165 then they will work on any older 8 lug ford
Old 02-08-2010, 05:29 PM
ok thanx man
