Auto Enginuity TPS Scan - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-22-2014, 07:56 PM Thread Starter
jrcrane1's Avatar
Question Auto Enginuity TPS Scan
Looking into an issue today after getting a CEL first start today. Does AE read anything for the TPS sensor on a 97 Powerstroke. Tried reading but nothing registered. Had the following DTC's:
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low imput
Module: Fuel And Air Metering
P0603 Internal Control Module Keep Alive Memory(KAM) Error
Module: Computer And Auxiliay Outputs
jrcrane1 is offline
post #2 of 3 Old 07-22-2014, 07:59 PM
ZMANN's Avatar
Quoted: 1596 Post(s)
you went to onboard monitoring and tried to load the TPS voltages but get nothing?
I may be off since the versions vary and so do the way the years behave
but thats how I remember doing the last one
We Miss you Ronnie
ZMANN is offline
post #3 of 3 Old 07-23-2014, 07:36 AM Thread Starter
jrcrane1's Avatar
AE and Throttle Position Sensor
Yes that is correct. No readings in data logging at all. They stay at zero.
jrcrane1 is offline
