2002 F250 Shaking - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-13-2014, 03:08 PM Thread Starter
millertime020311's Avatar
2002 F250 Shaking
I have an 02 F250 ext cab short bed. i have recently put a 6" BDS suspension lift, 37" Toyo open countrys and fuel rims. I have a new track bar, drag links, ball joints and wheel hubs. The other day my truck developed a disease of "dead pedal". So i put a new accelerator/sensor on and it worked beautifully. Then yesterday my tires ripped out the ABS sensor on my right front hub, i disconnected the ABS as i prefer not to have it. But now the whole truck shakes while im on the gas, the shaking stops when i let off the gas though. I think its something to do with the transmission but my buddy is saying something about the throttle body. Any help would be amazing as i am trying to drive home to Michigan from North Carolina in a couple weeks. Can also call or text at 616-460-9054 Kyle. thank you
millertime020311 is offline
post #2 of 2 Old 07-13-2014, 03:35 PM
sbluke55's Avatar
Quoted: 622 Post(s)
Garage
My guess is u joints or carrier bearing.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
Tags
f250 , shaking , throttle , transmission
