How much Blow by is acceptable? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-10-2014, 02:08 AM Thread Starter
How much air should be flowing out of the PCV port when the engine is idling? I have been reading a lot about hard starting problems, and I pulled the air intake off of the air box and turbo intake to check the glow plug readings. When I started the truck, there was quite a bit of flow coming out of the PCV port. How much is acceptable?
2001Powerstroking is offline
post #2 of 3 Old 07-10-2014, 04:53 AM
sbluke55's Avatar
Quoted: 628 Post(s)
Garage
You didn't give a year of the truck but guessing by your user name it's a 01. Take your oil cap off and flip it over and set it back on the fill tube. If it rattles off your good. If it blows off you have problems.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
2001Powerstroking (07-10-2014)
post #3 of 3 Old 07-10-2014, 07:55 AM Thread Starter
Simple, but effective. I like it! Thanks
