7.3 ZF5 will not shift into 2nd when downshifting - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-17-2014, 01:57 PM Thread Starter
pk64f100's Avatar
The truck runs great and is in good cond it just will not downshift into 2nd gear. I need help I am about to buy truck for $5000 but do not know if the trans is a bad decision, guy drives everyday and is noce truck 100,000 on motor and 245,000 on body & trans. Anyone help me make decision should I buy or run away? Thanks for the help!
pk64f100 is offline
post #2 of 3 Old 06-18-2014, 04:38 AM
It probably just need synchros. Mine would barely go into 2nd and 3rd when I bought it. Did the rebuild myself. Cost around $350.
Good luck
Mike97F350 is offline
post #3 of 3 Old 06-18-2014, 04:48 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes ^^^ if its in as great shape everywhere else then some bad syncros arent that bad as long as you have some extra Benjamins to throw into the trans to rebuild it (do a bit a research to make sure you want to do that). The zf5 is a pretty good trans especially compared to an E4OD.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
