04 6.0 problems - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-04-2014, 08:19 PM Thread Starter
Thumbs down 04 6.0 problems
i just became member
i have 04 f250 6.0 362000 miles its been a good truck.
it died five days ago replaced icp, ipr, ran for thirty minutes , i then drove 1/2 mile and it died
code shows 2617 crankshaft sensor open ckt
another scanner shows all 8 cylinders misfire
going to replace sensor tommorrow what about camshaft sensor any help please
ebcc is offline
post #2 of 3 Old 06-04-2014, 09:24 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 350 Post(s)
Remove a/c compressor and you will see the crank sensor. When you go to replace the crank sensor look in the hole and make sure the tone ring is still in the center of the hole. Also make sure (with a small screw driver and a small amount of force) the ring cannot spin on the crankshaft. I certainly hope its not that
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #3 of 3 Old 06-16-2014, 08:54 PM Thread Starter
Smile fried wires
after replacing ipr,icp and crankshaft sensor truck would not start , code still showed ipr open circuit so looked at wiring inside heat sleeve and found wires melted together. spliced wires and truck started . runs better than it has in a long time better fuel mileage also
ebcc is offline
