2005 6.0 Bad acceleration - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-30-2014, 05:18 PM Thread Starter
We recently bought this truck and it only has 81k miles. It starts and idles fine does not smoke white or black smoke and it has trouble getting up to speed once it gets passed like 40 mph. Ive read a lot of these forums with similar problems but most of them had smoke problems or some other thing that mine isn't doing. The truck runs great it just feels like it has no power once you smash the gas pedal. Anyone had this problem ? Like I said it runs and starts great and doesn't smoke it just doesn't want to accelerate at high speeds. Need Help Please!
Skeens00 is offline
post #2 of 6 Old 05-30-2014, 05:20 PM Thread Starter
I forgot to mention it also has a Water In Fuel signal on the dash. The truck is all stock but its supposed to have the EGR delete already installed.
Skeens00 is offline
post #3 of 6 Old 05-31-2014, 03:35 AM
Quoted: 2 Post(s)
I would start by draining your water seperator and changing both fuel filters if you haven't already.
2007 F250 Lariat FX4 CCSB
200,000+ Miles
SCT Livewire TS
Innovative Xtreme Street
Barder Stg 1.5
Arp Studs, Sinister EGR Delete
cudakid03 is offline
post #4 of 6 Old 05-31-2014, 04:16 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^Agree. what kind of boost do you build.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 6 Old 05-31-2014, 06:54 AM Thread Starter
Ok will try it. When we bought the truck it was a wreck slight damage to hood and headlights no serious damage the people fixed it and it sat a while im sure. I was reading and i think it could be the fuel pressure. On the stock gauge we are building low boost something lik 8 psi its hard to read. I know mechanics somewhat but im new to diesel. Thanks for the help
Skeens00 is offline
post #6 of 6 Old 06-25-2014, 04:02 PM
North Bend Stroker's Avatar
Change them fuel filters!
If you have a "water in fuel" read out, change the filters before you eat the injectors! The dealer can also add a lever kit to the water separator so you can service it more easily.
North Bend Stroker.
05 F250 Super Cab, 4X4, 6.0 L, Performance Machines coolant filter, Riff Raff CAC boots, K & N cold air intake, Scan Gauge II , AVS vent shades & bug deflector, Catch-it floor mats, Dee Zee truck box, side boxes and Headache rack, Tom-Tom navi, ICI wheel to wheel step bars, Huskey mud flaps and 5th wheel tailgate, RBW 5th wheel hitch, Hi-Lift tie-down rails, Rock-Tamer mud flaps, WD600 Icon wind deflector. 105,500 miles & counting!
North Bend Stroker is offline
