99 7.3 injector help - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-23-2014, 04:30 PM Thread Starter
I have a 99 f350 6spd 7.3 Im at a loss trying to figure out a problem I bought the truck with all new injectors in it and it blows white smoke (fuel) when im running threw town and runs ruff . When I get out on the highway it runs fine with all the power in the world. It keeps kicking codes for clylinder 5 not contributing and I put a new injector in still the same. Im at a loss any help ?
tomesee is offline
post #2 of 3 Old 05-23-2014, 05:42 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Is the valve cover harness good?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 3 Old 06-25-2014, 07:29 AM
Look at the #5 exhaust port. Which is the right side third one back. Is it wet? If so do a compression test on that hole. I had a customer bring me his and I done the same thing put a inj in still missed and was still smoking. I pulled the head and sure enough the cylinder was bad. Make long stories short a good used 7.3 fixed his problem
DieselBreathDude is offline
Tags
7.3 powerstroke problem
