Hard to start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-04-2014, 09:05 AM Thread Starter
Hard to start
Ok...check this one out...my 2007 power stroke is hard to start now when it's not been run recently...it's slow to accelerate,won't shift into second or third, seems like it's bucking back when I try to accelerate....Here's the kicker...after 3-5 mins,it's normal! Great acceleration and smooth shifting. The check engine light has just started to show its ugly head, but will disappear in a day or two, the surface again. Thoughts? It's got 95k on it...
Jdub737 is offline
post #2 of 4 Old 05-08-2014, 10:20 AM
My guess is fuel injectors...Same happened on my truck...They are sticky when cold and ran better when warmed up. The Check Engine light means the truck will throw some codes...I would guess some are reading low.
3drhino is offline
post #3 of 4 Old 05-08-2014, 07:45 PM Thread Starter
Thanks rhino....had the injectors cleaned at the dealer....helped a little bit, but it's back to the same ol sane ol...I am thinking I need some new injectors...thanks for the reply.
Jdub737 is offline
post #4 of 4 Old 06-25-2014, 07:33 AM
The injectors are scuffed. When the Inj's are cold the tolerance is great but when the engine warms that tolerance is taken up. And for the rest of the day it's fine right? If so look for a set of 8
DieselBreathDude is offline
The Following User Says Thank You to DieselBreathDude For This Useful Post:
Jdub737 (06-27-2014)
