power steering problems - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-31-2014, 01:48 PM Thread Starter
Wonder if anyone can help me with this, 2000 f250 7.3. I just replaced the p.s. pump but have the same problem - no p.s. Could this be the gear box? If so, how do I get to it and how can I know it's the problem? Any help would sure be appreciated, I'm a newby at this. Thanks in advance.
jayr5578 is offline
post #2 of 2 Old 01-30-2015, 12:59 PM
BamaStrokin's Avatar
Powersteering
Jus't read your post. I know it's almost a year old but I thought I would see if you found your problem. I'm having the same one. Have replaced the steering gear box and the PS pump and it still steers hard. If you have any info that might help I would appreciate it. I'm thinking maybe a seized ball joint or tie rod end, I will check those next. Thanks.
Early 99 F-250 Supercab 4x4, DP Tuner 40HP tow tune, BTM muffler, Rear SuperSprings, 400K and rolling.
BamaStrokin is offline
