7.3 WTS light stays on, no power to fuel pump - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mtneer7.3
post #1 of 6 Old 03-23-2014, 05:53 PM Thread Starter
2002 F-250 7.3 101,000 miles. When I turn key on, WTS light and CEL comes on but will not go off. Maybe a coincidence but this happened after batteries were dead. Replaced them and now cranks but won't start. Had helper check voltage to fuel pump when I turned key on 0 volts. Also have power to GPR but not out. Have checked fuses -all ok. Checked relays by switching. Checked for tripped inertia switch. The WTS light staying on puzzles me, is this a PCM issue?
Mtneer7.3 is offline
post #2 of 6 Old 03-23-2014, 06:27 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
Sounds like it...low battery voltage might have fried the pcm
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 6 Old 03-24-2014, 03:24 PM Thread Starter
Thanks, Any advice on reman or used PCM.
post #4 of 6 Old 03-24-2014, 04:51 PM
Doesn't Even Care
Quoted: 69 Post(s)
Get one from a part out on here...look in the classifieds on here, the nation, or vBulletin the army. You'll find one
Nick
"The Mistress"
post #5 of 6 Old 03-24-2014, 04:52 PM
Doesn't Even Care
Quoted: 69 Post(s)
Make sure you get your pcm code and match it to the one you want to buy
Nick
"The Mistress"
post #6 of 6 Old 04-19-2014, 05:56 AM Thread Starter
Thanks for the help. It was a bad PCM. Found a used one and works fine.
HVAC SuperTech likes this.
