Will a late 04 intake manifold bolt up to a 03???? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-14-2014, 03:12 PM Thread Starter
Will a late 04 intake manifold bolt up to a 03? Please Help! I do not want to go through having to take the turbo off to access the ICP and IPR sensor. The old style in 03 had the branch connector at the back and the 04 up did not and its obvious why the remvoed it was to make things more accessable.
Hedhuntr is offline
post #2 of 2 Old 02-14-2014, 11:43 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 369 Post(s)
Ya it will bolt up but if you're still running the egr cooler then you will have to change the cooler and the up pipe because they're different. If deleted then you're all good.
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
