Cranks, almost start but can't - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-11-2014, 05:55 PM Thread Starter
My truck doesn't want to start in cold weather. I crank the engine and only fires a few times per attempt. I checked the glow plug relay and it works the way it should. Everything works the way it should when the key is turned on. I think the glow plugs are bad. I need some advise.
Powerstrokeman25 is offline
post #2 of 6 Old 02-11-2014, 06:15 PM
x96535's Avatar
Do you have the ability to plug it in? If so, does it still have the same problems? You could be looking at a low voltage FICM or bad glow plugs. Mine was doing the exact same thing. I installed a heater cord and it started right up after plugging it in for a while.
2005 F-250 CCSB 6.0L: SCT X3, IDP Tunes, CTS Insight, 2.5" Leveling Kit, 35" Toyo's, 20" KMC Wheels, Rancho 7000's, EGR Delete, ARP Studs, Updated FICM, Built Tranny, '03 Turbo, 3" Downpipe, 4" MBRP Exhaust, Blue Spring Mod, 20" Lightbar, Door Seal Mod, BedRug, UnderCover Flex Cover, Badges Shaved, Painted Grille, Handles, & Mirrors, HD Headlights, Tinted Tails, 5% Tint
x96535 is offline
post #3 of 6 Old 02-11-2014, 06:22 PM
Do a voltage test on the FICM!
2004 F350 6.0 FX4 Lariat Crew Cab Short Box SRW Egr Delete, ARP Studs, Coolant filter, Edge Juice with Attitude, Blue Spring Fuel Upgrade, Banjo Bolts, Straight Pipe Exhaust, 19X,XXX
partsmark72 is offline
post #4 of 6 Old 02-11-2014, 06:33 PM Thread Starter
I do plug it in so it starts right up in the mornings. In the afternoon, after school, I struggle to start it. If I don't plug it in, I'll be sitting there for half an hour, literally, trying to start it. Each time this happens, I need a jump. I checked everything, and I think it's the glow plugs themselves that are bad.
post #5 of 6 Old 02-11-2014, 06:45 PM
Bet your right!! Order the harness for both sides because the boots on the harness always break when you remove the glow plugs!
The Following User Says Thank You to partsmark72 For This Useful Post:
Powerstrokeman25 (02-11-2014)
post #6 of 6 Old 02-11-2014, 06:51 PM Thread Starter
I'll get the whole glow plug kit with gaskets, harnesses and the plugs themselves.
Tags
7.3 , cold starting , glow plugs
