7.3 glow plug short. Fried the system. Throwing codes please help!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 02-09-2014, 06:04 AM Thread Starter
HunterER7's Avatar
Well Friday I had a major malfunction after installing the new stancor glow plug relay. The BULL**** Autolite plug failed, shorted the system and fried up. Seemed that the glow plug fried the drivers side uvch and plugs. So I thought. I ran around like crazy to get the parts for yesterday so I could get my truck back on the road.
I got all new motor raft plugs. And new uvch's. I got everything installed and all yesterday. When I got done I tired the truck on and now the check engine light is on. Run my code reader through my edge cts and I'm throwing two codes and the trucks limping
P0603(Internal Control Module keep alive error)
P1316(Injector Driver Module codes detected)
What the hell do I do? Someone please help here
7.3 Crew Cab Long bed.
Stage 2 AFE intake, 4" MRBP turbo back, Stage 2 Full Force injectors, Adrenaline HPOP, Driven diesel Regulated return fuel system, Custom tuned TS 6 position chip, Edge evolution CTS gauge, Built Trans
Estimated. 380-450 hp
HunterER7 is offline
post #2 of 13 Old 02-09-2014, 06:31 AM
460+'s Avatar
It might have fried the IDM. You need to ohms test the engine harness from the valve covers to the IDM. If wiring is good replace the IDM.
99 F350 4x4 dually
7.3 w/K&N af
4" exh into 6" Aussies stacks
4"lift &35" tires
CC mod HP crossover line
Beans stage II 120hp injectors
D66 turbo
ITP regulated return
reburn on TS= 25,high idle,60,100,120,140hp
updated ecm (2000 model)
Dyno#'s 360hp and 965 ft lbs trq
460+ is offline
post #3 of 13 Old 02-09-2014, 06:38 AM Thread Starter
HunterER7's Avatar
Will the IDM replacement fix the P0603 code?
post #4 of 13 Old 02-09-2014, 07:26 AM
RAMKILLER97's Avatar
The P0603 code means you have reprogrammed your PCM or I believe it can even trip from disconnecting your batteries. That code is not something to worry about.
2003 Excursion Eddie Bauer 7.3
6 Inch ProComp Lift, 315/75/16 BFGoodrich All Terrain Tires, BTS Transmission, 175/100 P.I.S. Injectors, PMF Traction Bars, Garrett 38r, International Up Pipes, Dyno Proven Tunes, 6.0 Transmission Cooler, CCV mod, MBRP 4" Turbo-Back Exhaust, RiffRaff Over Boost Code Regulator, Moto Metal MO951 Black Rims, Dual Sky Jacker Steering Stabilizers, GlowShift Gauges, Mile Marker 449SS Lockout Hubs, 6637 Intake.
Putting this old PMR truck to the test....
RAMKILLER97 is offline
post #5 of 13 Old 02-09-2014, 07:29 AM Thread Starter
HunterER7's Avatar
Okay cool yeah I removed the batteries to pull the intake and boost tubes. I can clear that code then and replace IDM and hopefully the truck will be good?
Are there any type of IDM I should be looking at? I have to replace it might as well help myself if I have to
post #6 of 13 Old 02-09-2014, 08:22 AM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 465 Post(s)
Have you checked your fuses? Sometimes gpr will not totally blow a fuse but it will put an arc in it. Only way to tell is manually pull the fuses out and check for arc. Or use a test light. One side will be bright. The other will be dim. Good luck
Sent from AutoGuide.com App
@loxdce
LoxDiesel is offline
post #7 of 13 Old 02-10-2014, 05:34 AM Thread Starter
HunterER7's Avatar
ive checked the fuses. one was bad but nothing serious. it didn't do anything. the way i see it is the idm is probably shot.
post #8 of 13 Old 02-10-2014, 06:07 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
clear the codes and see if it comes back...BTW the KEM is like others said batt disco. I'd clear it and see if it comes back.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #9 of 13 Old 02-10-2014, 06:09 AM Thread Starter
HunterER7's Avatar
Yeah I've tried that. Truck runs like ****. The IDM is definitely shot. There's no clearing this code. But the p0603 is just a memory reset from disconnecting the batteries.
post #10 of 13 Old 02-10-2014, 06:11 AM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
if it running bad then I'd agree...that or check the hpop system (icp/ipr) just to rule it out.
dannanw is offline
