'00 7.3 warm up valve problem - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-08-2014, 05:30 AM Thread Starter
When I start my 7.3 in cold weather, a butterfly valve just after the turbo closes to hold exhaust gasses back to help with warming the engine up. After a few minutes, it opens back up. Once I start driving, it keeps closing. No matter how warm the engine is, the valve keeps closing. I have to give more throttle, or take my foot off the throttle. I can't figure out the problem. Any advise on what the problem is?
Powerstrokeman25 is offline
post #2 of 9 Old 02-08-2014, 06:18 AM
bad thermostat
POWER-STRUCK is offline
post #3 of 9 Old 02-08-2014, 06:26 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
its closing once the truck reaches operating temp?
you can unplug the connector to the pedestal and that will make it stay open.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 9 Old 02-08-2014, 11:08 AM Thread Starter
I made a mistake. I'm having problems with the EBP valve on the exhaust side of the turbo. It keeps activating no matter what the engine temperature is. If I give the engine throttle, or take my foot off the throttle it'll deactivate. Then it will activate again when I return to the desired engine speed. I looked at the exhaust manifolds and saw a rusted off pipe on the front of the passenger side manifold. I can't tell what the pipe goes to. I will appreciate any advise?
post #5 of 9 Old 02-08-2014, 12:40 PM
Quoted: 258 Post(s)
are you saying the up pipes or the ebpv tube to the ebpv sensor?
unplug the connector at the base of the turbo pedestal and this will cause the butterfly valve to stay open
post #6 of 9 Old 02-08-2014, 01:31 PM
put in a new stant 14269 or dieselsite t-stat and solve the problem
post #7 of 9 Old 02-08-2014, 01:56 PM Thread Starter
I looked at pictures and found out that it's the small pipe that connects the EBP sensor to the front of the passenger side exhaust manifold. The pipe rusted off the manifold. It's an easy fix. I'll buy a new one.
post #8 of 9 Old 02-08-2014, 02:09 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I've never seen this advised as a fix.
OP: You can unplug the EBPV at the base of the turbo.
Also, that tube you see is the EBP sensor tube. Sensor is at the end of that. I wouldn't just unplug it, but fix it
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 9 Old 02-08-2014, 02:19 PM Thread Starter
I'll replace the tube and make sure everything else is working.
Tags
7.3 , back pressure , turbo , warm up valve
