04 powerstroke problem - Ford Powerstroke Diesel Forum
post #1 of 3 Old 01-21-2014, 09:38 AM Thread Starter
I have a 04 that has had EGR delete, headgaskets&studs,high pressure oil pump,ficmand turbo replaced I am running the SCT tuner. My problem is its hard to start in cold weather and takes spells where its like the truck is running out of fuel and then it picks up and runs fine , the only codes are P0069 map and P1000 probably caused by the SCT. Any ideas ?
Danny D is offline
post #2 of 3 Old 01-21-2014, 10:08 AM
information regurgitator
NYC F-350's Avatar
Quoted: 51 Post(s)
How does it start when you remove the tunes?
Have you checked your FICM voltage?
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 3 Old 01-21-2014, 12:59 PM Thread Starter
It makes no difference with or without the tune and I haven't checked the voltage.I just had a new ficm and high pressure oil pump put in at ford about 3 weeks ago.
Danny D is offline
