2003 6.0 no start after icp replacement - Ford Powerstroke Diesel Forum
post #1 of 16 Old 01-18-2014, 09:20 AM Thread Starter
hey guys. replaced the icp sensor on my truck the other day. the truck started fine before the replacement with the exception of long hot starts, but after the replacement just cranks and cranks. i also replaced the cam position sensor yesterday thinking that may have been the problem. i was able to start it once but that was it. itll just turn and doesnt even try to hit. i dont have a scanner so i cant provide codes, just hoping somebody has been down the same road and been able to figure it out. thanks
chris1221 is offline
post #2 of 16 Old 01-18-2014, 02:44 PM Thread Starter
ok how about this, can anybody tell me what the voltage values at the icp, ipr, and cam sensor should be? and like i said, it started before the icp replacement but unplugging the new sensor didnt help.
post #3 of 16 Old 01-18-2014, 08:00 PM
Huge Mythical Beast!!
LoxDiesel's Avatar
Quoted: 330 Post(s)
Ive never seen or heard of a 6.0 cam sensor failing. As far as ipr replacement im assuming you did it yourself? Big factor did you make sure you plugged in the 3 harnesses to the FICM properly? Do you hear the injectors cycle when you turn the key on? You can unplug the icp and the engine will run
@loxdce
LoxDiesel is offline
The Following User Says Thank You to LoxDiesel For This Useful Post:
chris1221 (02-03-2014)
post #4 of 16 Old 01-20-2014, 02:33 PM Thread Starter
alright, for your first three questions yes, yes, and yes. as for unplugging the icp, i did and it still didnt want to start. im starting to think it may be a problem with the fuel system like a bad relay or fuel pump or something. im not sure though
post #5 of 16 Old 01-20-2014, 04:46 PM
LoxDiesel's Avatar
Quoted: 330 Post(s)
The fact that it ran before hand and now it doesn't could be faulty ipr. The dealership i buy from has warranted quite a few here lately.
@loxdce
post #6 of 16 Old 01-21-2014, 04:54 PM
LoxDiesel's Avatar
Quoted: 330 Post(s)
Have you popped off the oil filter and had someone turn it over to see if you Low Pressure Oil Pump is working. When cranking the bowl should begin to fill up. Its best to watch since the drain valve is open when the filter is out so oil will leave the bowl.
@loxdce
post #7 of 16 Old 01-22-2014, 12:02 PM
ICP voltage on the sense wire (the one by itself in the connector, or c terminal) should be at 1 volt or above cranking. You would measure CKP in hz. The hz should be proportionate to cranking RPM so you should see at least 120hz.
winnersdieseltech is offline
post #8 of 16 Old 01-29-2014, 04:22 PM Thread Starter
sorry guys i havent had a chance to reply lately. i popped the oil filter out the other day, and the truck started instantly and spewed oil every where, but when i put the filter back in it didnt start. ive since tried that again with no luck, i also changed the oil which didnt change anything. i havent been able to check the voltage at the icp connector, but should be able to this weekend. i'll also be getting a Matco scanner from a buddy of mine tomorrow so hopefully that will help or atleast give me some more info to relay. all in all the truck hasnt run for a little over two weeks now which has been super inconvenient. one question i do have is, say its a relay or pcm problem, is there anyway to check or test those components with a VOM, and what should i check? thanks for the replies guys
post #9 of 16 Old 02-03-2014, 04:48 PM Thread Starter
just wanted to update anyone who is still following this thread, i was finally able to hook a scanner up to my truck today. after reading and clearing the computer a few times the truck finally started. the one code that showed up a couple of times was p2289 icp to high/ engine off. that eventually stopped showing up after a couple of start up's. the one problem i'm still having is its still not wanting to accelerate well if you really get on it but im almost positive thats a fuel delivery problem. anyway's thanks to all who gave advice.
post #10 of 16 Old 02-03-2014, 06:02 PM
Sounds like a biased ICP sensor. Get a sensor and connector from Ford. Verify that Icp pressure is zero key on, engine off.
The Following User Says Thank You to winnersdieseltech For This Useful Post:
