2001 7.3 engine randomly missing - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By mashthegas
  • 1 Post By studdgage
post #1 of 7 Old 01-16-2014, 07:31 AM Thread Starter
Lilsinkko's Avatar
I have a 01 F350 with the 7.3 and I took my muffler off and it's 4 inch through I don't know if that is the problem or not. When I'm driving the check engine light comes on and it sound like its running on half power. If I shut the truck off and back on it runs fine. I have checked the valve cover connectors and shimmed them. The truck will also correct itself sometime just by letting it run. Any insight to this problem will help.
CODES
P1316
P0340
P0470
Lilsinkko is offline
post #2 of 7 Old 01-16-2014, 07:36 AM
Check your warm up valve, it sounds like it's sticking.
Lilsinkko likes this.
mashthegas is offline
post #3 of 7 Old 01-16-2014, 07:47 AM
studdgage's Avatar
maybe even a cam position sensor Mine acted up off and on with no regular schedule ended up being the cam position sensor
Some people are like slinkies they are completely useless but they still bring a smile to your face when you push them down a set of stairs
studdgage is offline
post #4 of 7 Old 01-16-2014, 01:08 PM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
without looking through the codes does it have a chip? could be hitting the defuel level.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #5 of 7 Old 01-16-2014, 01:46 PM Thread Starter
Lilsinkko's Avatar
It's is chipped with banks but what is defuel level
post #6 of 7 Old 01-16-2014, 03:13 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
And you Still have a 1316? After doing the UVCH?
I'd be thinking IDM....
NoRalPh is offline
The Following User Says Thank You to NoRalPh For This Useful Post:
Lilsinkko (01-16-2014)
post #7 of 7 Old 01-30-2014, 08:07 PM
Have an 01 F-250 and my 7.3 does the same. Idling engine light goes off and runs normal. Go down road and it comes on and runs half power and missing. Did you find your solution?
oval4life is offline
