06 6.0 V8 F-250 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-24-2013, 06:24 PM Thread Starter
06 6.0 V8 F-250
I hope someone on here can help with what could be wrong with my truck. At 2000 RPM's and 70 MPH I start hearing a noise that sound like the truck is gasping for air followed by a vibration. All temps and gages read good. Once the vibration starts if I let off the gas or push on the gas it stops. Then it will repeat the same thing a few miles down the road. Usually it takes a few hours of driving before the truck starts acting up but today it only took about 30 minutes. I've put over $7000 into it trying to get it fixed in the last 3 months with no luck yet.
Things I've had done
1. Injector control pressure regulator
2. Injector control pressure sensor
3. fuel injectors
4. valve cover gaskets
5. battery's
6. quick disconnect kit
7. plug and tube kit
8. fuel fliters
9. FICM
10. 2 oil changes
Any help would be greatly appreciated!!!
BWaitman is offline
post #2 of 2 Old 12-29-2013, 11:09 PM
What kind of air intake do you have? How long has it been sence the filter has been looked at. If its a k&n Who oiled it? Get a EBP reading, have one hooked up so you can read it when the problem starts. Good Luck Stan
stanauto is offline
