99 7.3 jerking at cruise - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-09-2013, 05:40 PM Thread Starter
My problems all started when the truck quite me and it turned out to be the IDM which was replaced with a reman. Ever since the truck, not all the time but most, starts jerking at a steady speed as though the engine were being turn off and on. Take it out of OD and it usually can not be felt anymore. It is the worst at low rpm.
wyattschulz is offline
post #2 of 2 Old 12-23-2013, 06:24 AM
Have you tried it with the cruise on ?. If it doesn't do it, it's most likely the AP switch. (fuel pedal) Find a friend with the same truck and switch it out to try it. 3 10mm bolts, will take a min.
602rocks is offline
