Water pump went out 2 days after replacing serpentine belt. Related? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-02-2013, 06:50 PM Thread Starter
2006 6.0 F250. I just had the oil cooler and EGR cooler replaced as a proactive measure. While under the hood, the mechanic noticed my serp belt was getting frayed. I noticed coolant was leaking the day after I had picked up the truck. I also noticed that there was a bit of a ticking/clunk intermittently as the belt was turning. I couldn't tell if that was due to the belt rubbing something, or what. It was only briefly, and I haven't heard it since. I initially thought the leak was from the donut gasket under the intake, but a pressure test really opened up the leak at the pump. Has anyone heard of a belt change resulting in the water pump being taken down? Do I have another faulty part that caused the belt to fray, or that took out the wp after the belt was changed and full tension restored?
The mechanic who did the initial work said it was all just a coincidence. Ummm...helluva coincidence.
jawjadawg is offline
post #2 of 3 Old 12-07-2013, 02:54 PM
heisman01's Avatar
Quoted: 52 Post(s)
If the pump was on the way out it could cause excess ware on the belt, how many miles are on the truck and when was the belt last replaced?
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #3 of 3 Old 12-07-2013, 03:04 PM
ZMANN's Avatar
Quoted: 1485 Post(s)
how many miles ?
i replaced mine at 90K just for giggles I went with the BPD unit
u can't do anything stupid while changing a belt to wipe out a water pump on the 6.0
IMHO specially with the auto tensioner
was the leak at the weep hole or the o-ring ??
We Miss you Ronnie
ZMANN is online now
