2002 7.3 problems - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-18-2013, 01:33 PM Thread Starter
2002 7.3 problems
I have a 2002 7.3L powerstroke with approx 103000 miles on it. When I start it the truck will run fine for about 10-15 minutes then quit. I have changed the fuel pump and fuel pump relay but that has not helped as it continues to do the same thing. Does anyone know what it could be? I would appreciate any help. Thanks
Clinton2323 is offline
post #2 of 8 Old 11-30-2013, 03:27 PM
racerx250's Avatar
can someone help his member?
Bump
Sold my F250 1997 7.3L Bone Stock
Now between 6.0
7.3
racerx250 is offline
post #3 of 8 Old 11-30-2013, 03:41 PM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Either is running out of something important (like Fuel or Oil pressure) or an electrical component is crapping-out as it gets hot.
On a 7.3 the common failure for warming up is the CPS and that's where I'd start. Every 7.3 owner should carry a spare so, if you replaced it and it didn't cure the problem, your old one would be yours
They're not expensive, but I would Not buy an aftermarket one, goto Ford.
Next thing to consider is the Engine Oil. Is it Low? Is it in need of changing? (old foaming oil will do that)
In the end though, NOTHING is gonna beat a good scanner to monitor what's going wrong as it dies. Unfortunately, despite the OBD-II port, our trucks are Not, specifically OBD-II and the generic scanners (like the Parts Stores use) are of little use. You need a professional scanner to work right.
btw: you would have gotten many answers to this in the 7.3 Forums below, this is not really the right place to ask...
NoRalPh is offline
post #4 of 8 Old 11-30-2013, 04:38 PM
2002 7.3 problems
I agree with NoRalPh. Very good chance it is a faulty Crankshaft Position Sensor (CPS) which is located just above the harmonic balancer at the engine front cover. Check to see if you're getting a voltage signal to your tachometer while you're cranking....your ECM gets it's tachometer signal from the CPS. If you're tach is dead when you're in a cranks-but-no-start condition...most likely culprit is a defective CPS.
This issue may not sow up as a DTC even when hooked up to a good quality scanner. I've had two go out over the last 8 years and in both situations there were no troublecodes present.
Crank Some Heavy Metal is offline
post #5 of 8 Old 12-01-2013, 06:18 AM
Quoted: 157 Post(s)
Yea, But,,,, on an '02, the tach is No Longer driven by the CPS (as it was on earlier trucks) and not supposed to move while cranking. This change occurred during the '01 run and effects 1/2 the '01s and All the 02's&3's
NoRalPh is offline
post #6 of 8 Old 12-01-2013, 10:15 PM
Thanks NoRalPh. I was not aware of the change of the tach source. So just out of curiosity...where does the later '01's & up get thier tach input signal from?
post #7 of 8 Old 12-01-2013, 10:17 PM
racerx250's Avatar
Clinton?????
What ever happened ?
Now between 6.0
7.3
post #8 of 8 Old 12-02-2013, 05:39 AM
Quoted: 157 Post(s)
Oh it's still from the CPS I'm sure!
At some point in '01 the electrical system went through an upgrade that included a redesigned Instrument Cluster (as evidenced by the addition of a Trans Temp Gauge there). The Tach in the cluster was no longer driven, as directly, by the CPS (either was the new TT gauge ). So you now got "interpreted" info the PCM wanted you to have, one of which was no tach reading during cranking.
The new cluster became more of a Module itself and actually replaced some of the GEM functions too...
NoRalPh is offline
