fuel leak 02 excursion 7.3 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-06-2013, 01:16 PM Thread Starter
Send a message via AIM to don33taw
Hi Guys, I seem to be getting a fuel leak on my 7.3 I traced it to the area of the fuel drain. Its not the short hose that goes to the metal line, it looks like the black drain assy. I see 2 screws holding it to the filter housing i was wondering if that part is available of do I replace the whole heater filter assy? any thoughts, Thanks Don
don33taw is offline
post #2 of 5 Old 11-08-2013, 10:47 AM
fuel leak
Hi don
Real easy
I just rebuild the whole thing on my e 350
But on ur case u just take those 2 screws out pull that drain out and order the o rings from dieselorings.com
Good luck
fedeavakian is offline
post #3 of 5 Old 11-30-2013, 06:47 PM
If you're in a pinch and you don't have time to wait for the replacement o-rings...If they're not too flat and brittle, you may be able to just flip the original o-rings around in the drain valve assembly. That option worked for me and lasted for about two years on my '99 Superduty before it started weeping again.
But like fedeavakian mentioned, the best thing is to just re-seal the valve assy. with new o-rings.
Crank Some Heavy Metal is offline
post #4 of 5 Old 11-30-2013, 07:52 PM
Quoted: 725 Post(s)
U can also temporarily get by with using a piece of rubber fuel hose.
Corey@CNCFAB is offline
post #5 of 5 Old 11-30-2013, 10:02 PM
over200's Avatar
Quoted: 5 Post(s)
Just buy a new valve assembly from ford $40.73 and be done with it!
2000 F350 CCLB 536 k+ miles still runs like a top!
Diablo chip, quickie pedal, valve body, Air Force One air intake, MBRP system, XD Diesels w/ MT ATZ's, KL5H Train Horns / Air Zenith supplied.
over200 is offline
