Gas Mileage - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-20-2013, 03:33 PM Thread Starter
Gas Mileage
I recently acquired a 2008 F350 with 65,000 miles on it that consistently returns 11.8 mpg, after purchasing a Econ tuner and reprogramming the computer my gas mileage increased to 15.6 mpg, in search of further gains I was told to increase the free air flow would return even greater mileage so I installed a K & N high flow air intake system but instead of having the desired affect my gas mileage was reduced to 13 mpg, has anybody ever run into this? any tips on increasing Mpg on this monster would be greatly appreciated
Ksumm is offline
post #2 of 10 Old 10-20-2013, 03:43 PM
luke7.3's Avatar
Quoted: 24 Post(s)
It's the emissions crap. Get a DPF delete pipe and a Spartan programmer. I'd recommend an AFE intake but since you already have an aftermarket one you should be fine. The two items cost around $1800 and I recommend River City Diesel because they're fast and don't screw things up. Keep in mind you can't run the truck without the DPF without the programmer. This should bump you up to 20 mpgs easy.
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #3 of 10 Old 10-20-2013, 03:48 PM Thread Starter
Do you know of any company in the Columbus Ohio area that I could get to do the work?
Ksumm is offline
post #4 of 10 Old 10-20-2013, 04:19 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Found a company on google called columbus diesel supply. It looks like they have a performance division and they could install this system for you. If you can't find one, you get get the DPF off yourself and the new pipe on in about 2 hours or less. The programmer just plugs into the OBD II, super easy.
Luke
luke7.3 is offline
post #5 of 10 Old 10-20-2013, 04:55 PM Thread Starter
Thank you coalroller I will call them tomorrow I absolutely love love love my truck, its the king ranch version with all the tricks, just thirsty
Ksumm is offline
post #6 of 10 Old 10-21-2013, 05:19 PM
luke7.3's Avatar
Quoted: 24 Post(s)
No problem man. Yep, they're thirsty trucks stock because of that exhaust filter cleaning crap. Let me know what you found out
Luke
luke7.3 is offline
post #7 of 10 Old 10-21-2013, 05:30 PM Thread Starter
Columbus diesel wouldn't do it, they said its illegal, I found a local company that will for about $3400 parts and labor, he explained that the increased airflow causes increase soot in the exhaust filter which apparently functions like the afterburner in a fighter jet and pumps raw diesel into a chamber that ignites the unburned hydrocarbons to reduce emissions output, so the increase soot requires more diesel to burn it off causing the decrease in fuel effeciency
Ksumm is offline
post #8 of 10 Old 10-21-2013, 06:24 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Yes, its illegal and don't worry about getting caught unless Ohio has emissions inspections. My truck passes the Illinois safety inspection but luckily we don't have emissions testing. Is that $3400 with the Spartan programmer? Even if it is thats a lot of money for half an hour of work they could do it in. You could save $1400 doing it yourself even though its a pain in the ***
Luke
luke7.3 is offline
post #9 of 10 Old 10-22-2013, 01:01 AM Thread Starter
Yes $3400 does include the Spartan programmer he said that was the best on the market,I wish I had the confidence to do it myself but I am afraid it may exceed my mechanical ability
Ksumm is offline
post #10 of 10 Old 10-22-2013, 07:35 AM
luke7.3's Avatar
Quoted: 24 Post(s)
Haha, I don't blame you. That DPF and DOC has to weight about 150 lbs. You'll love your truck after doing it. It will have some wicked power.
Luke
luke7.3 is offline
