97 4x4 psd 7.3 no start no crank no wts no tack HELP! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-16-2013, 05:47 PM Thread Starter
ok so my truck dies on the road yesterday i thought it was the cps so i changed it out didnt work tested all fuses none blown so my question is if i have no tack and no wts light is it the idm or ecu what test procedures should i go though ?
mightydave45 is offline
post #2 of 4 Old 10-16-2013, 06:13 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Diagnosing a 7.3 no start
Check this out may help you
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 4 Old 10-16-2013, 06:20 PM Thread Starter
"ramstein" thanks sound like its the pcm cause the idm doesnt control gp's and i already did everything else in the recent past
post #4 of 4 Old 10-17-2013, 06:16 AM
Chapter Director
Quoted: 5 Post(s)
Well just because it was replaced recently doesnt mean it couldnt have went bad. You should test the other things first before you shell out for a new pcm One thing you should try is (with key out of ignition) unplug the pcm and plug it back in and make sure its tight. Thats what my no start situation ended up being.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
