6.0 PSD "Oil change required" on LED dash - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-14-2013, 12:16 PM Thread Starter
Hello,
My 2009 e350 is equipped with the 6.0 PSD engine. I just had the oil changed on 18.5k miles, and now, at just under 20k miles, the dash display shows "oil change required". Is this one of those generic service messages that pop up and given intervals, or has is the engine equipped with some sort of senor that has detected problems with the oil? I know some of the newer engines estimate oil changes based on usage patterns, but I do not think the 6.0s are so equipped.
Thanks for the help.
DJM
djm68 is offline
post #2 of 3 Old 10-14-2013, 09:29 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Reset oil service light Ford E 350 Series. From years: 2009, 2010, 2011, 2012.
How to reset oil service light Ford E 350 Series.
Oil Life Reset and Start Value. An oil change is required whenever indicated by the message center and according to the recommended maintenance schedule.
To reset the oil monitoring system to 100% after each oil change Ford E 350 Series. From years: 2009, 2010, 2011, 2012 (approximately 7,500 miles [12,000 km] or six months) perform the following:
1.Switch the ignition ON, do not start the engine.
2.Press and release the SELECT/RESET stem to display “OIL LIFE = XXX% HOLD RESET = NEW”.
3.Press and hold the SELECT/RESET stem for two seconds and release. Oil life is set to XX% and “OIL LIFE SET TO XXX%” is displayed.
4.To change oil life 100% miles value from 7,500 miles (12,000 km) or six months to another value, proceed to Step 5.
5.Once “OIL LIFE SET TO XXX%” is displayed, release and press the RESET control switch to change the Oil Life Start Value. Each release and press will reduce the value by 10%.
Note: Oil Life Start Value of 100% equals 7,500 miles (12,000 km) or six months. For example, setting Oil Life Start Value to 60% sets the Oil Life Start Value to 3,000 miles (4,800 km) and 120 days.
OIL LIFE CHANGE SOON. Displayed when the engine oil life remaining is 5% or less. When oil life left is between 5% and 0%, the ENGINE OIL CHANGE SOON message will be displayed.
OIL CHANGE REQUIRED. Displayed when the oil life left reaches 0%, the OIL CHANGE REQUIRED message will be displayed. OIL LIFE OK displays after you have changed the oil.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 3 Old 10-15-2013, 02:58 PM Thread Starter
Greg,
Thanks for the reset info -- definitely helpful. Looks like the message is triggered based on mileage (7,500) or time (6 month intervals). Since I have not come close to the 7500 mile mark, I take a look at my service records and see how long ago I had the oil changed.
Cheers,
DJM
djm68 is offline
