2000 7.3 excessive cranking times - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-11-2013, 12:02 PM Thread Starter
Looking for some hints - 2000 7.3, good batteries, good cranking speed, needs to crank about twice as long as others to start, hot or cold, cool or hot weather. Once it fires it is fine. Thanks
Powersmoke*2000 is offline
post #2 of 8 Old 10-12-2013, 11:07 AM
Bmurr99's Avatar
Check the fuel lines up front by the fuel bowl/filter housing for a a leak, check oil level and condition, check for high pressure oil leaks and also for fuel condition. Oil level and quality is a huge factor on HEUI trucks. I had one in the shop yesterday with the same symptoms and it had a slight leak from the fitting on one of the fuel lines- one in specific leaks often, the one that runs from head to head behind the fuel bowl.
-Britt
2000 F250 ext. cab super duty
7.3L Powerstroke, A/T
6.0L IC
XDP AIH delete
Custom 6637 intake
37x12.50r17 Falken Wildpeak A/T on XD BLACK. Wheels and 39.5x13.5 Irok's on Pro comp wheels
Foil delete/ painted CAC tubes,
CCV Mod,
Warn hubs,
MBRP 4 inch straight pipe,
Edge Evolution CS Programmer,
12" icon lift.
Bmurr99 is offline
post #3 of 8 Old 10-12-2013, 11:51 AM
blue99stroker's Avatar
Quoted: 246 Post(s)
fuel and oil pressure.
check your icp, if theirs oil coming through it, its time for a new one.
then if that doesnt fix it and you dont have any fuel leaks might need a new ipr.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #4 of 8 Old 10-12-2013, 01:14 PM
Bmurr99's Avatar
Blue99 is also right, although IPR and ICP issues will usually cause the truck to run poorly but can also affect starting. IPR valves are usually pretty solid, Check the IPR wiring harness (back of HPOP, and towards the bottom), and the ICP harness will sometimes get covered in oil and will need to be cleaned or even replaced. That's an easy connector to find, but the IPR harness is tougher, uses te same connector as our injector harnesses though so you could pilfer it from one of those.
-Britt
6.0L IC
XDP AIH delete
Custom 6637 intake
CCV Mod,
Warn hubs,
12" icon lift.
Bmurr99 is offline
post #5 of 8 Old 10-13-2013, 04:43 AM Thread Starter
Thaks for the replies. But could you give it to me in English?
post #6 of 8 Old 10-15-2013, 11:31 AM Thread Starter
I appreciate the suggestions, but I don't know what the abbreviations are. If someone would take a minute to spell out what the problem might be it would be great. Don't want to trouble anyone too much, but just need a little direction here!!
post #7 of 8 Old 10-16-2013, 09:53 AM
I am no diesel mechanic, so take this with a grain of salt.
Your truck actuates the fuel injectors by hydraulic pressure, created by the HPOP (high pressure oil pump) and regulated by a injection pressure regulator (IPR) and measured by an injection control pressure (ICP) sensor.
Check for leaks around the high pressure tubing - if there are any, the system will need to purge air and re-pressurize the high pressure side before the injectors will open and the engine starts. I think you'd end up with a rough start too - not just slow to start.
Is there some kind of check-valve in the fuel line from the frame mounted fuel pump? I wonder if the fuel pressure is taking some time to build up before the HPOP.
Greg
hammong is offline
post #8 of 8 Old 10-16-2013, 10:38 AM
Ford7three's Avatar
The IPR ( Injection pressure regulator ) regulates the oil pressure that is going to the injectors, if its stuck Open or closed it will not properly regulate the oil pressure and cause hot and cold idle issues, also check the ICP sensor that is located on the drivers side head behind the Alternator. Unplug this sensor when you are cranking the truck over and see if it starts easier or not. If it does, replace the sensor.
Ford7three is offline
Tags
7.3 , hard starting , long cranking time
