No Hot Start...How Much is This Going to Cost Me? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-06-2013, 12:57 PM Thread Starter
Ok, I have posted on here once or twice about this truck. This is where I'm at right now with it:
I have been fighting with this 2004 f350 with the earlier 6.0 engine in it ever since I bought it almost a year ago. Took it to a local diesel guy, he replaced the FICM, alternator, both batteries, cleaned the turbo (it also wasn't working), and replaced the ICP sensor. Still wont start after the engine is hot. Then he says it must be a high pressure oil leak. So he test drives the truck a bunch over the next 2 weeks, and says he cant get it to act up again - it starts right up every time. So we bring it home, go inside for 10 minutes, come out and turn the key....and it cranks and cranks and cranks...but will not start. Back to square one. So I called another diesel place and he said it definitely sounds like a high pressure oil leak. So I made an appointment to have it fixed. But my question is does anyone here know how much this will probably cost? He said they are at $65/hour in his shop. He explained everything to me on the phone, and I've seen videos on youtube of people finding the issue themselves, seems like an alright job if you know what you're doing. I have never done anything like this, and I have a brother that is a diesel tech, but doesn’t mess much with the smaller trucks like mine. So would we be better off letting someone else take care of it and spending a bunch of money, or trying to attempt it ourselves? Thanks a ton guys for any help. I'm stuck here and just want it fixed - without spending a bunch more money on it! Oh-forgot to add. We also changed the IPR valve ourselves. The old one that we pulled out was trashed, totally missing the screen.
Jsrebel is offline
post #2 of 3 Old 09-06-2013, 03:06 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
I'm not a 6.0 guru, but it sounds like the snap to connect(stc) fitting has broke. It will give this problem. Could be the hpop, but not totally sure. I'm sure someone else will come on and help you more
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 3 Old 01-24-2014, 08:51 AM
Sounds like you have a high pressure oil leak. If your ICP sensor is on the valve cover, its a job 2 2004, if the sensor is on the HPOP cover, its a job 1, which is basically a 2003. JOB2: To check for a HP oil leak at the rails, I disconnect the injectors electrically so they cant push oil from their spill spouts. Have someone crank the engine while you inspect the areas under the injectors for leaking oil where they connect to the rails and the dummy plugs on the front of each rail. Reseal as needed. If you find no leaks, replace the STC fitting with the updated branch tube adapter and retest. JOB1: These trucks have the straight oil rails and rarely leak from them or their supply hoses. You can check them for leaks in the same way. If no leak is found, replace the HPOP, as these trucks do not have a STC fitting. Hope this helps.
winnersdieseltech is offline
